Panasonic nn-st49s bpq blows fuse when door is opened.
Martcam
Epsom
NN-ST479S BPQ
Panasonic
I've changed the door latch and the lower 2 interlock door switches as these seem to be the common solution to the problem. No joy though, Oven works fine for 10 minutes or so then the fuse blows if I open the door. Appliance is not running when I open the door...any ideas?
Hi, as much as we would love to help you, we can't, your European model is completely different than the USA models.
Try a European forum called UK Whitegoods.
