pavt244aww - black ruber under washer
r272
Smyrna, DE
Hi, my performa PAVT244AWW is 2 years old, a few days ago my daughter put in 2 heavy blankets at the same time, by the time I came in from outside, there was a burning smell from the machine. Since then, when we do a wash, after the water fills and when it's time for it to agitate, I still smell a little burning and I have to open the lid and close it in order for the machine to pick up speed.
Today, I pulled the machine out and looked under it and there was a lot of black specs and tiny peices of what looks like black ruber. I also noticed that there is what looks like a belt from a car underneath and that's where the smell is comming from, my question is is the belt just worn and needs to be replaced or is the motor going?:confused:
r272
Smyrna, DE
Thank you
Thank your for your response, i'm not sure how I would know if the motor pulley is bad or not, should I just be looking for a hole in the pulley or should I just replace the belt, as it appears to be only the black dust and what could be black plastic. Maybe I should order both parts to be safe?
Thanks, Glad to help.:)
r272
Smyrna, DE
water leak
my wife decided to try a load today and we noticed some water coming from under the machine. Is this something that happens when the belt is bad? Just want to know before I order my parts incase it's something else.
No, that usually doesn't happen when the belt is bad, you may need to pinpoint where the water is coming from inside the cabinet or underneath, were your water pump is.
Here's a help link for access help:
http://www.applianceaid.com/atlantis2.html
Ok, sounds good, let us know the outcome.:)
