Payne PG9MAA036060 - Error code 12
buriboi
canada
PG9MAA036060
-major brand-
Hi all,
Before I blow some ungodly sum on an after-hours callout, I'm looking for some quick advice.
My PG9MAA036060 Payne gas furnace isn't turning on at all when I call for heat at the thermostat.
Opening it up, when I turn the power off and then on again, the red LED is flashing 1 short, 2 long. That code is listed on the inside of the door as "BLOWER ON AFTER POWER UP - Blower runs for 90 seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens during blower on-delay." So this is not the issue.
But when I turn the power off and on again, the error code eventually changes from that start-up 1-2 to the *real* code: 3 short, 4 long:
"IGNITION PROVING FAILURE"
This error code has a whole paragraph afterwards with a million different possible issues (oxide buildup, defective gas valve, defective hot surface ignitor, low inlet gas pressure, etc, etc...). Furnace tries to cycle 3 more times, then the 1-4 lockout code.
Sounds like I need an HVAC tech. Any quick checks for a newbie before shelling out the big bucks? $$$
