FIXED PB905ST1SS GE Profile electric burner not working.
TomE55
MAryland
PB905ST1SS
The front left electric burner is not working and the "Hot Cooktop" light for that burner is on.
Unplugging the stove (flipping the breaker) did not solve the problem.
May I assume I need a new element?
If so, what is the difficulty scale in getting under the glass cook-top to replace it.
Hi Tom, I'd first turn the breaker off to the range then ohm test that front left element.
Here's that front left element for your model you can order if yours tests bad:
WB30T10133 Element Radiant
I find 9 times out of 10 when that heat light indicator stays on, the problem is in the element.
Here's the video to ohm test it:
Here's the video to remove/replace it:
Your welcome Tom, let us know what you find.
TomE55
MAryland
OK. Just want to make sure I am doing this right. I followed the video you showed me and got these results. If I understand this correctly, my outer coil was ok. My inner coil is not. This means a new element will fix the problem. Thanks in advance for your help!
You are correct Tom, the inner coil is bad, yes order and replace the element and you'll be back in business.:)
Sounds good Tom, yes keep us posted.
TomE55
MAryland
Got the part yesterday. Took all of 10 minutes to put it in. Burner works great now.
Thanks a million Jake.
I obviously couldn't have done it without you.
Happy New Year!
Excellent Tom, glad to hear the new front left element burner fixed it. (y)
Happy New Year!
