PB975SP5SS GE Ovens goes off after turning on
bsaucer
Alabama
PB975SP5SS
This ranged worked while I was testing it at the store. It stopped working after it was moved to a customer's house. You turn on either oven and press start. After a few seconds the oven would go out. I tried to push "clock", "timer" and "start" to retrieve error codes, but the "timer" button doesn't respond. After unplugging it and plugging it back in, it kept showing a F760, until you set the clock. Is there a way to fix this without replacing expensive parts? I wonder if it might have gotten wet (It rains a lot here), or bumped while moving.
It sounds like the UI board (NLA). Check the connections. Turn all four burners on high for about 20 minutes. That will dry out any moisture in the control panel.
