ahart2001
- PDT750SSF5SS
- GE
- 6-10 years
I have a PDT750SSF5SS dishwasher that is throwing an F96 error code. Originally I was getting several error codes (I know F99 was one of them) and all of the threads on here were pointing the Flood Switch and/or Turbidity Sensor. I went ahead and replaced both the Flood Switch (thermistor) and the Turbidity Sensor with brand new genuine GE parts. Now I am getting the F96 error alone which is "No Water in Tub (turbidity based)". I have gone into the Service Mode and run the Drain Pump and Water Valve cycles (to drain it out and put a fresh load of water into the machine) so there is definitely a tub full of water. I ran the Circulation Pump and Heater cycles as well and I can hear the dishwasher parts working; no extra codes are coming up on the LCD.
For reference, I got out a multimeter after still getting this F96 code and checked the old Flood Switch and it tested at 12 ohms which I thought was curious because that is in the range that indicates good (not sure why a new one would clear the previous codes, but oh well, a win is a win).
The whole problem started with the dishes not drying. The machine runs in ordinary use, but it is not getting hotter when running in the Boost and Sanitize temperature modes. The water temperature is getting hot from the hot tap water alone.
I have checked the Turbidity Sensor wiring harness and there doesn't appear to be any damage. I guess I am down to the Inverter Board and the Pump (w/ integral hidden heater). I would have assumed that if the hidden heating element was bad it would be throwing a F97 or F99. I'm not getting any of the fault codes indicated in the Inverter and Motor Diagnostics (page 56 of the manual).
On the Heater Diagnostics (page 87 of the manual), it states to remove connector J703 and check for resistance. I did this and am not getting a reading (maybe the heating element is shot?). I went ahead thru the other steps and checked the voltage of J703 on the board and am getting 120V (looks like the Main Control Board is ok).
So 2 questions:
1. Would a faulty heating element be causing an F96 code?
2. Why wouldn't a faulty heating element be causing a code (like F97 - Absent Heat Source)?
3. Before I go dropping $150-$200 on a new pump/heater, is there anything else I should check?
4. Is there a way to check the Turbidity Sensor with a multimeter (so I can make sure the new part isn't defective)?
So 2 questions:
