PDT825SSJ0SS GE Dishwasher lights up, blinks, beeps, doesn't start
Petro91
PA
PDT825SSJ0SS
I have a GE Dishwasher PDT825SSJ0SS that was working fine. When I try to run it, the orange light blinks, beeps and the dishwasher never starts/ I read several your posts about similar issues.
I tested the door by holding Cycle Select and Start for 5 seconds, etc.
I checked the control board and its not steady off or steady on. The control LED on the board is continuously blinking, about 1 time ever 2.5 seconds.
Do I need a new board or is it something else?
1x per 3 seconds: Dishwasher in not running a cycle. Select a cycle and press Start.
Lets ohm test the door latch first. If the door latch ohm tests good, then the machine control board is the culprit.
Here's the machine control board for your model:
Here's the door latch switch for your model:
WD21X10490 Latch Switch
Follow the directions here:
Door closed: 0 ohms.
Door open: infinite ohms.
Let us know what you find. Make sure you disconnect power to the dishwasher before ohm testing.
Petro91
PA
Ok, thank you both for your response. I am not a professional, just a home owner that tries to figure out things on his own. Ha.
I wouldn't know how to use an ohm meter after I bought one.
2 Questions:
1. So the blinking light doesn't indicate anything in particular one way or another?
2. Should I just buy both parts and install the door switch first and try it. If that doesn't work replace the board?
Thank you.
1x per 3 seconds: Dishwasher is not running a cycle. Select a cycle and press Start.
No. That method of appliance repair will get very expensive, very fast. The first thing you need to do is get a DMM (Digital-Multi-Meter). A good one costs about $25. You can pick one up at any of the home centers or Walmart. It will probably take you less than 15 minutes to figure out how everything works. You'll find it be the most valuable tool in your tool box. It pays for itself with the first repair. It comes in handy for a lot more than just appliance repair.
FYI- My mom can use one. She's 94.
Watch this video too:
Anytime Rick!
