FIXED PDT825SSJ0SS Three beeps and no start - door reporting open
chris98891
Greenville, SC
PDT825SSJ0SS
Hey all,
I have a 2 year old dishwasher that isn't starting. Thanks to this forum, I've tried all kinds of stuff.
This happened about 2 weeks ago, and shutting off the breaker for 5 minutes fixed it.
This time, I've tried everything. Reset the breaker, ensured demo mode wasn't on, and ran the service test with the door closed. With the door closed, it flashed like it was still open.
The service LED doesn't appear to be lit.
In this case, I had planned to replace the control board, but I'm concerned the breaker reset fixed it the first time, but not this time. Are could there be any other causes I should check before replacing the control board?
Thank you all in advance!!!
Chris
Hi Chris,
It sounds like your door switch is bad. Try that test again and report back.
With the dishwasher in Standby Mode (Cycle Selection Mode), press and hold the Cycle Select and Start buttons simultaneously for 5 seconds.
On entry into the Consumer Error Mode, the control reports the door status for 10 seconds.
--->All LEDs are solidly illuminated, if the door is detected as closed.
Here's the door switch latch assembly for your model you can order if needed:
Door Latch WD21X10490
There is a "HOW TO" video in the part link to access/replace it.
chris98891
Greenville, SC
Thanks Jake! Ran the test again, even with the door closed, all LEDs flash.
Would it make sense that the service LED is also not illuminated if the door switch is bad?
Ok, so the STATUS LED is OFF completely? If so and your getting 120 volts to it, then yes the control board is bad.
Here's the control(machine) board for this model you can order:
chris98891
Greenville, SC
Welp - I dropped the machine board again to recheck all the connections. Lo and behold, service LED is flashing and it now works fine. I did turn the breaker off for a couple minute while I was dropping the machine board, but maybe just a loose connection that got made while I was dropping the board?
Thanks again for the help! Guess for now I'll just keep going until the issues crops up again.
Ok Chris, sounds good.
Yes, let us know if it acts up again.
chris98891
Greenville, SC
Wehlp, it happened again. Guess I was on borrowed time. Same symptoms as before, so I'm planning on buying a new control board.
Yes Chris, how many times is the STATUS LED flashing now on the machine control board?
chris98891
Greenville, SC
No light at all on the control board, even after checking all connections. I guess I also need to make sure the board is getting power.
Do you know of a good way to check that?
Yes, Look at the image of the control board I posted in post #4, see where its marked 120 VAC SUPPLY? That's where you put your meter probes to check to see if you have 120 volts there at the control board.
If your meter reads 120 volts there and the STATUS LED is STEADY OFF, then you'd need to order and replace the control board.
chris98891
Greenville, SC
Well, we came back alive briefly after this post, but we died again. I have the new control board in hand, but the new board has personality jumpers.
The old board had no jumpers at all, and the new board shows a configuration for a PDT825. Should I go with no jumpers like the old board or should i use the configuration on the sheet?
Thanks again for all the help!
Ok Chris,
You will need to use the jumpers configuration on the sheet that came with the new control board.:)
Viki87
Austin TX
Hi Chris,
I am running into a similar problem with my ge profile PDT825SSJ0SS
What was your final diagnosis and resolution? Would appreciate it if you could share with us.
Hi Jake,
Hi again! Almost a year back, the valuable resources here and your expert tips helped me replace the control board on my dishwasher and everything has been working smoothly since.. until yesterday that is..
Suddenly the dishwasher won't start. Upon pressing the start button, the orange light blinks 3 times as if it would when the door is open and does not start. The door seems to close just fine and seems to be making contact crisply with the door latch. I tried holding down select_cycle and start simultaneously for 5 seconds and all lights flash with code 817.
I haven't removed any boards to check any other lights. Does it appear to you like I need a new door latch or could the problem be something else? Would appreciate your guidance immensely here
Vikram
Hi Vikram,
Yes, you will need to ohm test the door latch switch, with a multimeter, to determine if its bad.
Here's the door latch switch for your model:
WD21X10490 Latch Switch
Follow the directions here:
Door closed: 0 ohms.
Door open: infinite ohms.
Let us know what you find. Make sure you disconnect power to the dishwasher before ohm testing.
Viki87
Austin TX
Hi Jake,
Apologies for the late reply here. I intended to reply right away, but forgot. So, just as I got ready to ohm test the door latch switch, the problem fixed itself. I am just running the dishwasher with fingers crossed since, hoping the problem doesn't resurface. :)
Vikram
Ok Vikram, since dishwashers can't fix themselves yet, you can expect this to happen again, unfortunaity.
If it started working on its own then it can't be the door switch and it has to be the machine control board, that has been the known problem child to fail.
You can order the machine control board for your model in post #4.
Viki87
Austin TX
Thanks Jake. As luck would have it, it did happen again today :( Will order and replace the main control board and hopefully that'll fix the issue.
Vikram
Ok Vikram, sounds good, keep us posted.
Viki87
Austin TX
Hi Jake,
I replaced the main control board today and the problem seems resolved. Thanks for your valuable inputs again! I really appreciate it!
Do you know of anyone who's had success repairing one of these control boards? Want to see if it is worth while to try to fix it and keep as spare or if I should just scrap the old board that came out.
Vikram
Excellent Vikram, glad to hear the new main control board fixed it.(y)
No, not as of yet. Sure you can always try.:)
