FIXED PEB1590DM2BB GE Profile Microwave Not Working
hginsburg
Pittsburgh
PEB1590DM2BB
I came home to a power outtage and once the power came back on, my microwave wouldn't work. The display screen is very dim (all but totally black), and if you try to start the microwave, nothing happens. I tested the fuses, capacitor, and switches. I've narrowed down that the control board needs to be replaced. Has anyone else experience this problem? I'd appreciate any opinions before I invest in a fairly costly part!
-Howard
hginsburg
Pittsburgh
Thanks for that insight. As I look to get this back up and running, I'm considering adding a single outlet surge protector to keep this from happening again. Any thoughts on that?
I don't have any information on surge protectors or how well they work. I usually tell my customers if the power goes out, unplug the machine until the power comes back on. I've seen this happen to refrigerators, microwaves, & ranges along with built in ovens.
hginsburg
Pittsburgh
I wanted to close the loop on this thread so that hopefully it will be of use to someone else in the future. Today my replacement control board arrived, and that was indeed the solution to my problem. What was interesting about this updated part was that it has a ground wire. The original board did not have this.
Thanks @rickgburton for the guidance. You saved me a bunch of money!
