PEB1590SM2SS GE PROFILE COUNTERTOP MICROWAVE TURNS ON WHEN DOOR IS OPENED
billgreen
Texas
PEB1590SM2SS
GE PROFILE MICROWAVE PEB1590SM2SS
Microwave starts up-turntable rotates- when door opened. No buttons are pushed.
Thanks Bill
billgreen
Texas
to clarify, all phases of the microwave work except,
When you open door to put food in, the tray starts to rotate fan comes on before any cooking buttons are selected.
Oven works properly when food is put in and door closed. Once cooking cycle is completed oven shuts off as normal. Once door is opened to remove food the turntable rotates and fan comes on.
Bill
Hi Bill,
Rick is our microwave expert, I'll see if he can help you.
The problem is probably related to a door interlock switch but could be the main board. There's three interlock switches on the latch bracket. Unplug the machine and remove the control panel. Remove the wires from the three interlock door switches (one at a time) and check the door switches for continuity by opening and closing the door. Probably looks like this
