sdynak
- PFE28KSKGSS
- GE
- 1-5 years
Hi there folks!!
I hope all are well. I have a 5 year old GE Profile refrigerator twin cool system that at times, it seems the fridge will not cool properly and gets erratic from a temp chart.
I have replaced the evaporator fan, the fresh food thermistor and the main board and still having this issue. Testing the thermistors from the main board all seem ok in a range to be expected so have not continued to replace more.
It will cool normally for like 6 hours and even longer at times and then it seems to go off once the doors are opened or once warm air / humidity introduced. It is strange as I'm seeing that pattern.
The evaporator is not freezing over when this happens, I am noticing the fridge evap fan is not running and it seems as if there is no signal to turn on. If I leave the door open long enough the fan will kick on before I can remove the cover but there is no frost covering it and the fan will come on before I can get to it btu can hear it when it comes on.
Looking back, I'm thinking something has not been right for a while but on May 25th to 26th there was a distinct change that led to higher fridge temps like in the low 50's F. My adjustments and changing the evap fan early on and fridge thermistor did help to get it back down. This was pretty sudden and nothing was changed till that time.
It seems there is a lot of humidity as can be seen on my monitoring sensor as well as just on the items in the fridge.
I have been proactively monitoring my fridge for about a year now just to ensure to prevent any issues such a door open or failure. I did put in a aftermarket thermistor and the resistance was off and when it ran, it took the fridge down to 26 F when it did cool which was too cold even if I set the temp to 37. So I got a OEM one and replaced it and that is what is in there now.
The freezer seems for the most part to work ok and is not following this pattern like the fridge.
Here are a few pictures of the chart where you can see the erratic temps. Some of the higher temps in the 50's are times when I was in there trying to observe what might be happening such as the last picture from today in the 50's. Mostly it will go into the low to mid 40's now when it acts up but 50 happened initially. I assume the intermittent 50 was the defrost cycle until it shifted all together.
If anyone has seen anything like this I'd be very thankful for any advice here. It doesn't seem like a defrost issue and pretty much everything has been replaced otherwise.
Thank you in advance.. Stan
