PFRS2MBXASS Temperature fluctuating in freezer on GE refrigerator french door model
VikJES1969
PFRS2MBXASS
On a daily basis (as far as I can tell), the temperature of the freezer fluctuates from 0F to 11F which, I know, this doesn't sound like much but I've also noticed the refrigerator is more noisy than it used to be (it was almost completely silent for most of the time before). I know 11F is still way below the freezing point but some of the food isn't frozen solid when it hits this temperature (it's obviously not thawed but it's noticeably softer), so could the temperature display showing me the wrong temperature also? It will hit this higher temperature for something like an hour and go back to its preset temperature (0F), I was told this is just the defrost process taking place but I've never noticed this process before.
That model number didn't pull up as good, please recheck it.
Click here: Appliance Parts
VikJES1969
Hi Jake,
The model number is : PFRS2MBXASS
I'm in Canada if that makes a difference (I presume model number between the US and Canada might not be the same) but anyhow here's a photo I took of the sticker that has the model and serial number:
Thanks in advance.
Ok,
Yes, some models from Canada we can't look up, this is one of them.
What I'd suggest first is to buy a freezer thermometer and put it in the freezer to monitor the temperature that way too.
You may have a bad freezer temperature sensor.
