PHP900DM2BB Glass-top range Error "-"
homhat
PHP900DM2BB
Hello,
I have an induction glass-top range (Manufacturer: GE /Model PHP900DM2BB). It has 4 burners and on the 3 out of 4 I see an error "-".
I checked the user manual to see what it means but was not able to find anything.
Any comment/clue?
Check for error codes:
Press and Hold the Front Right Burner ON/OFF key for 7 seconds until tone is heard and “1” appears on the timer.
Press and Hold Rear Right Burner ON/OFF key for 7 seconds until tone is heard and the Software version appears on the timer.
Press Left Rear + key to displays failure codes on the Timer.
Pressing this key multiple times will cycle through each failure code until dashes appear showing the end of the codes. If no active failures exist only dashes will be shown with each press.
Press and hold the All Off key for 5 seconds will clear the Failure Code that is currently displayed.
Press Left Front - key to exit test mode.
Post any error codes here.
