PHS920SF1SS GE induction stove top, Fa92 error code
Mcnabb75
Greenville SC
PHS920SF1SS
model: PHS920SF1SS
issue: Fa92 error code
FA9(X) dictates the burner. The second digit (2) dictates which burner. This one being the right front.
Code Meaning - coil temperature sensor break
Suspect Parts: a) coil sensor harness
b) cooking coil sensor
c) Generator board
Just found a wiring diagram that was not really helpful because it did not show the wiring for the sensor and generator board. Did come across a note that if either the coil sensor or the coil itself is bad to replace the complete assembly for problematic eye. fine, once I go back to look.
Problem being, how to determine if its the generator board, which seems impossible to get to. And also, how to determine if it is the coil sensor harness?
This shows the induction module and generator boards for a similar model:
Mcnabb75
Greenville SC
This one is set up different. When you take the top off the boards are attached to the glass. You have to flip the whole thing upside down and than there were not any screws to get the cover off the invertor boards. Awful design...
I haven't worked on that model yet and so far I haven't been able to find any info on it.
