PHS925ST1SS Induction range stopped working
ronlukowski
FL
PHS925ST1SS
Watching TV heard a loud pop coming from the kitchen. Couldn't find out what it was.
Next morning noticed range was not working. Oven light comes on when you open the door, but nothing else works.
Took off front control panel and back cover and visually checked boards - no visible signs of any burns or damage.
bigbuck
From Planet Mars
Here is your tech sheet and a service manual.
  • 31-14968 GE PHS925ST1SS Mini Manual.pdf
  • GE-Oven-PHS925-FS-Slide-in-Induction-Training-Manual.pdf
I'd first pull the range out from the wall, then unplug it from the wall, then remove the back access panel and see if your terminal block(where the power cord wires connect to your range) are burnt, I've seen that many times, and that will make a loud pop sound when the electricity arcs on your metal.
Look at this thread in my post #2: FIXED: JB700DJWW GE oven burnt black wire on cord
Your GE model uses the exact same terminal block.
Here's the terminal block for your model you can order, if needed:
Terminal Block WB17T10011
