PLHS269ZCB4 Frigidaire Refrigerator ADC controls damper motor?
leemd
maryland
PLHS269ZCB4
Frigidaire
I have a PLHS269ZCB4, does the ADC control the damper motor which is currently stuck in a closed position. The ref. temp control checks ok and the damper motor checks ok. I've had problems with ADC's failing before due to power surges. It usually shuts down all cooling but this time the freezer works but no cool air to fresh food side because the damper door won't open.
The problem is most likely ADC and/or one of the microswitches in the damper. The replacement kit is no longer available:
leemd
maryland
Thanks Rick! That's what I suspected, I'm on my third one and was lucky enough to find one of the original replacements online which is on order. Hopefully it works. No doubt the next time it fails the fridge will be graveyard bound.
Frigidaire had a lot of problems with the original style. That's why the update kit with wire harness.
You probably won't have long to wait...lol
