PRD3610NP Discontinued Door Hinge Question Jenn-Air
SixMyles
NC
PRD3610NP
Jenn-Air
So after lots of digging and conversations with Jenn-Air, the door hinges for my oven have been discontinued - Part number W10298134. I find it amazing that a 7 year old, rather expensive, oven would have high wear items such as door hinges discontinued. The recommended replacement parts are not compatible with the oven frame.
Has anyone else run into this issue or have an idea how to repair existing hinges?
For reference, what it is suppose to look like:
genuineapplianceparts.com/item/W10298134_Jenn_Air_Oven_Door_Hinge_36_Inch/4887
What the replacement part number looks like: WP73001109
Thanks anyone for the help.
I found it in-stock here: PRD3610NP Parts
WP73001109
How do you know its incompatible? Did you already order one and try to replace it?
SixMyles
NC
Yes, I ordered one of those already and tried. The stove frame wont accept a hinge that has 2 arms like the one you show. Look at the first link i have in my post.
Thanks for the reply
Got it, yes I see now.
I agree it should NOT be No Longer Available only after 7 years. I don't know what else to suggest.
SixMyles
NC
Nothing yet...I'm waiting to take the door apart over the holidays and hope I can shim the hinges to add more tension
MrCharlie
Vermont
Wow. I ordered the replacement part, and discovered that it didn't fit. I can't believe this.
I was thinking of making a latch on the sides of the oven to pull the door tight. Not sure that will work.
Good luck on the shim approach - can you explain more where you intend to place the shims?
SixMyles
NC
Either below or above the springs. I'll slide in some kind of space to provide more tension on the spring, so that it puts more tension on the door to keep it closed...that's the plan till I get it apart.
