MaximumSquid
- 100973-01 0609N0
- LG
- 6-10 years
Solved. . .
Link to the manual for the Lennox furnace control board: manualslib.com/manual/1077334/Lennox-G40uh-X.html?page=36#manual
Number on the board in the furnace:
100973-01 0609N093634 1012-969
From the manual:
DS1 LED (RED) = OFF
DS2 LED (GREEN) = ON "Flashing Slowly"
Prove switch open.
OR: Blocked inlet/exhaust vent;
OR: Prove switch closed prior to activation of combustion air inducer.
Last one turned out to be true.
To bypass this you will need rubber gloves on. Turn the furnace off and unplug the pressure switch.
Turn the furnace on and when the combustion blower turns on plug the pressure switch back in and you will have heat until it turns off again.
I will need to replace the pressure switch, but I can run it manually like this for the moment.
From the manual:
DS1 LED (RED) = OFF
Prove switch open.
