FIXED PT7550SF4SS GE profile Double Oven F35 Error
viper3344
Texas
PT7550SF4SS
Hello all!
Have a home with a GE Profile Double Oven Model PT7550SF4SS
Came with the brand new house built in 2015
Out of nowhere its started showing F35 on the lower oven and wont let either oven do anything.
Resetting it from the breaking fixes it for maybe 2 min then the error comes back up
Its REALLY hard to find what F35 means online but I went ahead and replaced both oven sensors (the probes in the rear of each oven) anyway thinking maybe that could be it. No dice :(
The 2 control boards inside blink red which I hear is normal.
The LCD control board is wb27x29601. That part is super easy to replace and wondering if anyone thinks that might be it?
Any help is GREATLY appreciated friends.
Thank you!
Corrected model number
Hi, Your missing a digit in your model number.
Here's the results I get:
PT9550SF1SS
PT9550SF2SS
PT9550SF3SS
PT9550SF4SS
PT9550SF5SS
PT9550SF6SS
PT9550SF7SS
PT9550SF8SS
PT9550SF9SS
Read it from the model number tag on the Double wall oven.
viper3344
Texas
Hi Jake!
So the correct model number is: PT7550SF4SS
I actually had a neighbor let me borrow their entire front touch panel assembly and I still get the error :(
Any idea what the F35 error is?? I literally cant find it anywhere. Thanks!
I can't locate error code F35 anywhere in your tech. data sheet either.
Hopefully another tech. or member that's run into this F35 can shed some light on it for us.
viper3344
Texas
I know right?? So odd.... Well would you be able to let me know the part numbers of the internal boards? I can start ordering those and swapping them out, Thanks!
viper3344
Texas
Hi Jake! Yeah already replaced the oven sensor and still getting the error. Guess I need to replace the whole board now which stinks. The manual you posted only shows pins through error #33 even though the header of the page says its through errors 35...
Have you seen that before on other ovens? Sensor error but it ended being on the board side and not the sensor side?
Thanks for all the input here!!
No, GE double ovens are not popular here in Western Arizona, so I have not seen F35 here locally.
But Pin 1 and Pin 8 go to the lower oven sensor.
