PT7800SH5SS - Double Oven...microwave acting up with buzzing sound
Justwait
Tampa
PT7800SH5SS
Convection works fine but using regular microwave makes loud buzzing sound when starting to run. Light and base spin but not sure that we get heat with microwave option. It’s only 1 year old.
OK, that just leaves the mag tube and transformer. Discharge the HV capacitor Disconnect the wires on the mag tube and put a piece of black tape over the ends. If it still buzzes the transformer is the cause.
If the buzz is gone replace the mag tube:
