FIXED PT970DR2BB Oven/Microwave Combo F9 Error
Happy in VT
VT
PT970DR2BB
Hi everyone,
My neighbor has the built-in oven/microwave combo and gets the F9 error every time she has tried to use the self-cleaning function for the past several months. She now says that it is clicking when they are near it. I have read other threads for GE Profile ovens that this is a fairly common problem, but I am not sure where to check for a failed/failing part. I have fixed my washing machine and dryer by replacing the control boards, but I'm not sure if it would be the control board or something else.
When they run the cleaning cycle the door does lock, but the oven never gets hot enough to actually clean before the F9 code happens. If I had a schematic of the wiring of the unit (or at least some instruction on what and where to check for voltage/resistance I would be able to help her figure out what is wrong and hopefully fix it for her.
Any help/advice that can be provided would be appreciated.
Jim,
F9 is a sail switch error. I have a tech sheet for a similar model. Try this; Press & hold the upper Bake & Broil Pads until “SF”appears in the display.
Then press and hold the 1 and 5 pads until "Product Test" appears in the display.
To Check Status of Sail Switch: While in service mode, press the Help pad.
Initially, the cooling fan should come on in low speed and the Sail switch will have an open status.
Pressing the Help pad a second time will toggle the cooling fan into high speed causing the sail switch to have a closed status.
Happy in VT
VT
I did some testing before I saw your reply. I was able to plug in my meter into the connector for the squirrel cage fan at the back on top of the oven. I'm pretty sure this is used to keep the controls cool during oven operation. When I turned on the cleaning cycle the voltage went up to 120v, but when I plugged it back into the fan the fan did not turn on. This leads be to believe that the fan is dead. Does that sound reasonable to you?
Happy in VT
VT
Perfect! I will let her know this evening and get it ordered. It looks like it should be a fairly straight-forward fix. I appreciate your help.
Happy in VT
VT
So I was able to get the new fan installed. I also installed a new thermal limit switch/fuse just as a precaution. Better safe than sorry. I did end up pulling the whole thing out of the wall and putting in on the floor. It was just easier than trying to be a contortionist and getting in behind it with it still half in. It fixed the problem and she is very happy now.
