PVM1870SM1SS GE Profile Microwave won’t heat. Only fan and timer works.
Dave__A
New Jersey
PVM1870SM1SS
About 2 months ago, the fan would still run with the door open. Microwave was off, just fan running. Seemed to cook just fine. Thought maybe door switch stuck? However, a few times when I opened the door before cycle over (instead of pressing pause) the circuit would trip. I’ve always done this.
A week ago, microwave stopped working. Fan would run and timer would count down, but food not heating. I can hear that it is only the fan. I then played around with it, trying time cook, starting/pausing, opening closing door, etc, and it started working again after 5 minutes. Worked for a week and now it’s not, for about 5 days now. Not sure if it’s worth trying to replace switches. If I do, can this be done without removing microwave?
Thanks!!
Dave
The 3 door microswitches and possibly the switch holder need to be replaced to make your MW oven work properly. Removing the grill at the top first, followed by the control panel will give you access to the microswitches. Sometimes if there's a groove worn into the switch holder caused by the 2 spring loaded "fingers" on the door, that will have to be replaced also. W10727360 is a universal switch that is inexpensive and readily available.
