FIXED PVM9215SF1SS GE Over the Range Microwave Not Heating
Punda Smith
USA
PVM9215SF1SS
Hello,
I bought my GE Profile Over the Range Microwave (Model#: PVM9215SF1SS & Serial#: DD207526B) around June 2014, and had it installed.
Recently, I realized that the microwave is not working:
-- the buttons light up when you press them
-- the light comes on in the microwave when you start it
-- the timer count-down works when you start it, as if it is actually heating something up.
BUT the problem is that: it does not heat anything up. It plate does not even turn around. only the light comes on.
Any possible ideas regarding what might be wrong ?
thanks - Punda
A copy:
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power smart board, but a bad door switch is most common.
If needed:
Micro-Switch-WB24X829--00613372.jpg LINK> Door switch
No pic LINK> GE Microwave Pcb main asm
Some access helps...
[video=youtube;czZHdMB5eEU]https://www.youtube.com/watch?v=czZHdMB5eEU&feature=player_embedded[/video]
Punda Smith
USA
jeff, thanks very much for your response. It's been a while. I finally received the switched, replaced it, but the problem is still there. So, any other thoughts ?
/thanks - PS.
BTW... I noticed you are in Ontario, Canada, where?
I used to there -- first, Kingston (@ Queens) and then Toronto (UofT) before moving to the States
Did the switch test as being bad?
Which one did you replace?
Are the switches opening and closing ok when the door opens and closes?
Door keys hitting the switch correctly?
No where near the Argos!
Punda Smith
USA
Actually, I didn't test the switch - maybe I should. With what ?
But the switches are closing ok when the door opens/closes.
I only replaced the top switch.
Do I also have to replace any fuse?
thanks - PS
Punda Smith
USA
thanks again, I used a digital multimeter and checked the part - it did have continuity. through a process of elimination, I realized that the bottom switch was faulty, so I replaced it, and the microwave is now working.
Thanks very much.
But another question, how do I get the 2 replacement screws that hold the LCD to the microwave frame ? -- I want to have them handy just in case, because I might have stripped them in the process of repeatedly tracing the faulty switch.
thanks - PS.
Good catch, a quick continuity check can help show what is good or bad for sure.
The parts breakdown doesn't show any screws....I'd take what you have to local hardware store and see if you can get a couple of extra ones.
