- PWE23KSKBSS
- GE
- 1-5 years
Hi all,
My freezer leaks water from the front during the defrost cycle. Ice will build up at the bottom of the freezer and once there's no more space for ice, water will leak on the floor from the bottom of the freezer door.
I've looked at the drip tube behind the refrigerator and it's clean and isn't clogged at all. If I had to guess (from other posts in this forum), there's probably a clog above the drip tube. I've attached a picture of where the ice builds up and where the water trickles down.
I would open up the freezer from the inside and remove the clog (if that is the issue!), but I cannot find the service manual and would hate to be in a position where I'm not able to put everything back together.
Any ideas of the issue? (and is a manual available?)
Thanks all!
Thanks all!
