lshunnarah
- PYE2300AYW
- Maytag
- More than 10 years
I have a Maytag PYE2300AYW dryer that will not heat. I have reviewed other threads on this forum that seem to have similar issues but none have helped me so far. I have replaced the high limit t-stat, the thermal fuse, the heating element and the cycling t-stat. I don't think the vents are clogged as I have done as much as possible to clean them. The dryer runs and everything seems to work as intended, just no heat. I've struggled to find proper documentation on what each part is and where it goes as the parts I've ordered don't seem to 100% match the description. I've tested with a MM and I do have continuity on all the parts. I'm a bit confused how the thermal fuse works though as there are no wires connected to it and it just seems to sit under the heating element. I'm not a professional so I'm sure it's doing something, just seemed odd to have a fuse with the connectors for wires, yet no wires plug into it. Any other suggestions? At this point I'm just wondering if all my parts are even the correct ones.
Thank you in advance,
Louis
Louis
