- PYE23KSD
Everything in our refrigerator is frozen (almost... it has ice forming). The bottom freezer is currently 25 degrees (I have is set to 32) and the top french door refrigerator is 31 degrees (I have it set to 37). I can hear it running and doesn't stop.
I powered it off for 10 minutes hoping a "reset" would help but it didn't. The LCD on the front of the refrigerator shows the inside freezer as 9 degree and the refrigerator is 42 degrees. However, I have placed two temp probes in there and it's 25/31 inside.
I trying to decide what could be the culprit? Temp Sensor (since the door reads different than inside). Perhaps the Thermostat (before I powered it off it read actual temp of 32/37 but it was much colder inside).
Anyone have any recommendations? I found the service manual (View attachment PYE23K.pdf) so I should be able to replace whats needed, just looking for advice on where to start.
GE Model PYE23KSDCSS
