jazzwineman
- QHM06LX
- GE
- Less than 1 year
This is the second Haier 6000 BTU (QHM06LX) unit I have gotten. I use this for zone cooling in my window near the kitchen and dining area as I do have Central air, but those areas are the furthest from the Central AC.
The first one lasted 2 summers and then started to freeze up at all temperatures. Either it developed a leak from nowhere or there was some internal mechanical problem. I clean the filter every week, keep the evaporator fins clean as well as the condenser fins. In winter I put a protective cover over the whole outside part as I do a more more robust install or weather and bugs would get around the unit with the windows I have. I regularly use coil cleaner on the condenser coils. There is zero problem with airflow at any location in the AC.
So I bought last summer another one just the same as before. Did my same robust install and then this winter kept it covered again.
Started it at the beginning of summer here in Texas and everything worked fine. Since I get the west sun in the afternoon in that area and I run it at high and set at 64 so that is runs al the time.
The other day it was 99. i was gone for about 70 minutes and came in and found it frozen on the top part of the evaporator and in the unit the suction filter and line to the compressor was covered in ice. It was a simple procedure in hot temps to unfreeze. I had cleaned the filter the night before and the evaporator coils/fins look brand new.
I then unplugged the unit, got my coil cleaner, sprayed it on the condenser coils/fins, let it do it's work and then hosed it off well and cleaned up the tray where bugs or pieces of leaves sometimes fall.
Started it up and all seemed to work well for the rest of Wed, Thursday and Friday.
Then Saturday in the middle of the afternoon with the temp at 99 degrees the same freeze up. The unit is clean, the coils and fins are clean, the front blower blades are clean, the condenser fan is 90% clean. Clearly there is either a malfunction of some sort or a coolant leak has come about from nowhere. It seems to operate in the defined specifications and the air coming out of the vents is about what I would expect using my IR temp monitor. Today I set it at 70 and left for about 90 minutes and it was starting to freeze again when I got back. Now if I turn it on and the condenser comes on, then 2 or 3 of the copper pipes going to the evaporator want to frost up quickly.
Apparently there is a serious reliability problem with these units and there seems to be no valid reason for it to freeze up being this new.
The only thing I might mention is that one of the vents of the Central Ac us nearby and may lower the temp of the air going over the evaporator coils. Could that be a problem?
Does anyone have a suggestion as to what could be the problem if not the machine. I have run it allowing water to drip and run it with the plug in for water to hit one the condenser coils. Would that make a difference.
Any help is highly appreciated.
Tom in Dallas/Plano
Tom in Dallas/Plano
