Quasar - How to check magnetron
ME2
Tennessee
MQS1108W
Have an old Quasar microwave that will not heat. Assume problem is the magnetron but not sure.
Since I just want it for drying small chunks of wood prior to turning on a lathe, do not want to take to appliance store to find out for sure what is wrong...not worth the cost. Is there a simple means to determine if magnetron is bad? If so, I can order the tube if available here and replace if it is not too difficult to do...i.e., no tools required that are specific to a microwave unit.
See if you can read the filament with an ohmmeter. It should read closed or 00.
ME2
Tennessee
Filament reads about .1 ohm, but filament to ground is also about 1 ohm but should be infinite....tube is shorted (fried and baked). PN from tube is Panasonic, 2M210-M1, and second line C08- 08292 V. Where do I post to get price shipping etc? Say hi to Jake...hope all is well.
JBall
New member
Nashville, Tn
I had a customer who used his microwave to dry his "herbs". The microwave caught on fire!!! As we all know, microwaves only work on moisture, i.e, water in the food. If you are drying wood in the micro, first, there is little moisture to begin with, and you are trying to remove the only thing the microwaves will react with... end result is magnetron failure. I'd use the oven at a low temp.. Just sayin'. JB
