Question about Samsung Microwave Coupler/Turntable Motor
wyclef
ny
mw620wa
Samsung
Hi, the turntable motor burnt out recently, fusing the coupler to the motor. Wouldn't spin at all. Replaced it with a new motor and coupler from here:
Turntable Motor DE31-10154D Order now for same day shipping. 365 day return policy. RepairClinic.com
Coupler DE67-60081A Order now for same day shipping. 365 day return policy. RepairClinic.com
Everything 'seems' to be working fine except I do hear a quiet slight tink tink noise after the microwave is complete and thought I detected the table spinning with a bit of resistance at one point although that could be my imagination. I'm going to keep an eye on it but am wondering if these motors have a break-in period? Also, is there a positive and negative terminal on the motor or does it not matter which side the black and red wire are attached to. Is there anything else I should be looking for here? Everything else seems to work fine.
That often is the metal coils on the magnetron contracting and cooling off...I hear it once in a while also.
Nope.
