Quiet Wash Plus Only Spins if You Open and Close Door
All Washed Up
MI
I have a 1993 Model DU8700XY-1 Quiet Wash Plus. Lately it seems a little to quiet. The pump seems to be running but unless you open the door (or just push the handle release) it doesn't seem to be pushing it through the system. I have noticed when I open the door the water will gurgle 2 or 3 times and when you close the door it is obvious that the water is again circulating. Any Ideas??? Check valve somewhere? anti-cavitation??:confused:
jmshaffer
pennsylvania
I've seen the valve stem go bad in these models. water will actually drain while washing and reduce pressure to pump, resulting in a situation similar to yours. You can try to order the valve stem kit. It's about 15 bucks.
Part #675496
