R-3A54 Sharp Microwave - Replaced fuse. Worked for a moment then new fuse blew.
Bilbo2001
NJ
R-3A54
Sharp
Sharp Carousel II microwave experienced a brownout. I confirmed the fuse was blown and replaced it (15A 250V ceramic). I was able to power on the unit and clear the display. I set it to cook for 5 seconds. It turned on briefly then went dark again. I confirmed that the new fuse is blown. Is it worth further repair? What else may be at fault?
Disconnect the two wires on the primary side of the transformer. Tape the ends off if necessary. Run the microwave on high for several minutes with a cup of water inside. If the fuse still blows check the interlock switches. If the fuse doesn't blow with the high side disconnected (no power) the problem is one of the high side components (transformer, mag tube, capacitor or diode).
