R930AK Older microwave convection oven carousel occasionally turns
Felix Delaroux
Oregon
R930AK
Sharp
This unit was produced in 2001. A few years ago, the carousel decided it would prefer to turn clockwise. The rare times it turns counterclockwise, it works great. Clockwise, not so much. It will turn a few times then just sit there and click. Thoughts?
Felix
Felix Delaroux
Oregon
Ha! Yah, I kinda came to the same conclusion — so what if it doesn’t turn? That said, the replacement motor is cheap enough it may be a worthwhile repair. Thanks, Dan!
If the turntable isn't rotating you'll get uneven cooking and maybe a slight chance of the microwaves being reflected back to the magnipetron tube, shortening its lifespan. Mainly just bad cooking results.
