Browndog
- GDT655SSJ2SS
- GE
- 1-5 years
Hey Jake
I've got a random wake up occurring on my GE GDT655 dishwasher. Can you straighten me out on the personality jumper settings? you quoted above
"NOTE--->When replacing UI control boards, the new UI Board MUST be configured as per the instructions included with the replacement. If the personality is not set by using the 4 jumpers, the buttons, LED’s or cycles will not function properly"
Sorry for the long story here but here is my history and confusion.
GE GDT655SSJ2SS Dishwasher
Unit started to randomly wake up, as if door was opened. Did not matter if door was closed or open for it to wake up. Continued to randomly wake up more and more often until it quit working all together. Dead. Replaced User Interface (UI) Still dead. Main Machine Control Board Status LED steady on. (Did not check for Low Voltages). Replaced Main Machine Control (MC). Still dead UI, MC status 3 blinks in sequence. Switched back to original UI, still a no go. Re-installed replacement UI with rechecking the wire harness and all interface connections. Yeah! We have control. MC status 1 blink every 3 seconds (Unit not running a cycle...). Ran couple loads, all well for 2-3 days. Now it has started with the random wake up again. Not as often but it is still randomly waking up with door open or closed. Could the Door Latch be cause of my issues? Why 2 switch contacts in this switch?
About the UI personality settings: The original factory UI board has the header pins installed with all 4 jumper blocks offset to open (1,2,4,8). The genuine GE replacement UI does not have any header pins or jumper blocks. The Circuit board has coating over the feed thru holes where the jumper block should be. The included UI personality instructions for 50+ GE models* show jumpers on 1,2,8, with 4 open for a GDT655 model. Now I'm confused as all the threads with reference to the personality jumper settings must be set properly for it to work doesn't make sense. Replacement UI appears to work properly but I do have this random wake up happening.
*No models listed has an open 1,2,4,8, configuration. 13 different settings, none are open configuration like the oem UI is set.
