Rattle noise when off
garym114
Texas
PLMV168KC1
Frigidaire
It makes a rattle noise when off, you can hear the same noise when it is on. When it is cycles off I can stop the noise by entering 'cook time' and a digit or two. Some times it takes entering a cool time, then clear, and entering another cook time. I just enter on the pad without actually starting it. It doesn't make the noise every time it cycles off, probably about 70% of the time.
It has been doing this for the last several months. Other than the noise it works just fine. The noise is coming from behind the keypad.
The stove and microwave match so I would like to keep it running. The magnetron was replaced about two years ago.
