RB171PW, 1994, Top Freezer, 18 cu ft. Water drops form on top surface of food compartment, and drip on food
Rob F
Bellingham, Washington
RB171PW
Magic Chef
Drops form on top part of food compartment and drip down on the food, and makes a puddle on the crisper area below the food racks. The food is cold, and the frozen food is frozen OK.
I am wondering if there is something wrong with the defrost heater or defrost thermostat. I have replaced the defrost timer with a new one. I can't figure out how to get access to the defrost heater, evaporator, part of the fridge.
Corrected model number
Need to recheck that.
https://www.applianceaid.com/model-number.php
https://www.applianceaid.com/appliance-parts-resources.php
Some model# helps.
Clogged or restricted defrost drain.
Soaked insulation as well as clogged or restricted defrost drain.
Bad defrost thermostats, soaked insulation as well as clogged or restricted defrost drain.
jeff sr.
Only trouble is.....that model# doesn't work for me at 3 different parts depots as a Maytag nor as a Magic Chef.
Do you have a picture of the model/serial tag?
I changed the Maytag to a Magic Chef.
jeff sr.
Rob F
Hi Jeff,
Here is a picture of the model/serial tag
Rob
That one works! :)
I use to have a tutorial on this....but couldn't find it.
Basics:
remove power
remove both doors
remove center hinge
remove center bar (between the FZ and FF sections)
freezer floor can now be flexed out towards you
heater and stats are under the FZ floor.
jeff sr.
Rob F
Thanks a lot Jeff,
The information you provided should be a huge help. I really didn't think I would ever find someone who would know how that is done.
Rob
This link here may also help.
Edit: Link worked earlier but not now :confused:
jeff sr.
