RCS10D Amana Commercial Microwave HV Transformer
K.Connell
Florida
RCS10D
Amana
Recently replaced the HV Transformer that had one primary input terminal burnt off. There are three input terminals. Between the first terminal and the burnt terminal the resistance reads .6 ohms. Between the burnt terminal and the third terminal (slightly larger spade terminal) the resistance reads .2 ohms. Between the third terminal and the first terminal the resistance reads .6 ohm. Can anyone tell me what the third terminal is for and can I use it in place of the burnt terminal. My mains is 120 volts. Thank you in advance
