RDSCG230 Viking range igniter working intermittently
Akurio
RDSCG230 (D3)
Viking
I moved into a suite with a viking RDSCG230 (D3) range and the oven has been causing me some grief.
The igniter often fails to ignite during the cooking process, usually 10 - 20 minutes after the desired temperature is reached (oven indicator light goes off to indicate this). It tries to ignite five times (clicks for awhile, stops, repeats) and after the fifth time I have to turn the oven off and on to have it start the process again. In some cases the igniter does reignite after restarting but often it does not. This makes the oven unusable as I'm unable to finish the cooking process.
The igniter does ignite every time I turn on the oven initially to preheat.
The problem occurs at various temperatures and bake settings (conv bake, bake, broil).
Any help would be much appreciated!
