- KRSC700HBS00
- KitchenAid
- Less than 1 year
We bought this fridge less than a year ago, and the ice maker & water dispenser have been working good once we plumbed in the lines for it, we have changed the water filter once since then.
Today I was getting some ice from it and noticed ice stopped coming out, so checked the ice storage bin and it was totally empty. Yesterday I had removed the bin to dump some ice in a bag, and it was full to the top.
I can tell there is ice in the little tray on top, but it is not dumping in. There is a white plastic arm that I assume is the ice level indicator that is up beside the ice tray, but I don't recall every seeing it in a down position. Since the ice storage tray is made to be easily removed in this model if that arm was down you would not be able to remove the tray, so I am a little confused what its purpose could be. If this isn't the full indicator, how does it know if it's full or not?
I pulled the tray out & let all the ice buildup melt away, turned off the ice maker and wiped away any ice build up I could see in the freezer door, the flipped the breaker for the fridge off for a good minute before turning it on, turned the icemaker back on but still no ice
The freezer temp is set at -18c, I put a thermometer in on the top shelf for about 5 minutes and the readout was -15c.
We have been having unusually hot weather (for northern Alberta) for the last week where out inside temps were often about 30c, but the fridge/freezer seem to have been working fine.
The water dispenser is still working fine.
This should be under warranty, but getting warranty work done on appliances up in this area is a challenge at best of times, so it possible I'd like to see if I can troubleshoot it myself.
Thanks in advance
Thanks in advance
