joelkonicek
- mcbr1010gs
Recently replaced defrost timer - now freezer is at 0 degrees, frefrigerator will not go below 43 degrees even at max. Is this thermostat defective since temp control know only controls air flow i asusme thermostat temperature sensor is fixed at some predetermined termperature? Can you replace such a device with an accurate variable electronic control since it simply activates compressor. I see no way of adjusting temperature accurately - am i missing something?
