Removing old under cabinet mounted Sharp Carousel II microwave
dbsteeth
R-1420B
Sharp
I have removed two bolts from the cabinet that insert down through the cabinet floor into the microwave mounting kit top. Nothing gives way though, and I see no other bolts or screws to loosen. Any ideas would be appreciated. Thanks
Some have spring loaded hooks at the back bottom and you need to pull down on the release tab(s). Sometimes the vent hood can get caught and prevent the microwave from rolling forward to come off of the mounting plate.
jerff.
dbsteeth
Thanks, Jeff. You were exactly right. The vent hood was holding things up.
David
