FIXED Replacement Fan Motor for Sears Portable Heater Needed
wordbuilder
Tucumcari, NM
I think the heater is from the '70s (cone shaped and orange). It's 1500-watt, from Sears. The heating element and power switch work fine, but the fan motor just vibrates and fails to turn. Can anyone point me to where I might find a replacment? The shaft is smooth and protudes from the top 1/2".
Its best to take that fan motor to your local appliance parts store in your area, they can likely match it up with a GEMLINE or universal one.
wordbuilder
Tucumcari, NM
Thank you, Jake. My town doesn't have an appliance parts store but I'll be in Albuquerque in a few weeks so I'll take it along with me and hope they can help me out.
I might also suggest a HVAC parts supplier.
There looks to be a Johnstone Supply in Albuquerque. They might be a good choice as they sell both appliance and HVAC parts and supplies. They might even have an online catalog you can look through. You're looking for an "open frame, shaded pole motor". The stack thickness and shaft diameter are likely most important. The rotation is usually reversible. 120V AC of course.
JMO
wordbuilder
Tucumcari, NM
Very much appreciated, Dan. I'll look for an online catalog. Either way, I'll probably drop by Johnstone Supply when I'm in Albuquerque. Knowing the name for this type of motor should help in my search.
wordbuilder
Tucumcari, NM
I struck out at Johnstone. I held it up and the guy at the counter gave it a quick glance and said something along the lines of, "We don't have anything like that."
I'm surprised! I'll look for a universal motor catalog you can browse through.
wordbuilder
Tucumcari, NM
Thank you, Dan. I'll try to find something online as well. I'm just worried I'll get the wrong thing. I don't even have a caliper to measure the diameter of the shaft. I could use a ruler and hope I get it close enough.
A ruler should be fine. There won't be too many shaft choices 1/8", 1/4", 3/16" possibly by looking at the pic. The stack thickness will vary too.
Here's a Canadian catalog. I'm not sure if you can get them in the USA
LINK > http://www.alltemp.ca/wp-content/files_mf/1446839245rotom_master_v40.pdf
wordbuilder
Tucumcari, NM
Thank you much, Dan. I really do appreciate it. I feel kind of dumb for missing that information earlier. I'll get a motor ordered and check in again when I get the heater put back together.
wordbuilder
Tucumcari, NM
I finally got the time to finish this project. The new motor was a bit larger in size than the original motor. I had to shorten the shaft and also flip the bolts over so the threaded ends protruded from the bottom instead of the top. Doing so gave them nothing to screw into so I used the nuts from the original motor which I had to install to secure mounting brackets anyway. The fan noise is a little louder than most modern space heaters and, since this heater was broken when I got it, I have no idea how the sound compares to when it had the original motor. Thanks to everyone who helped me out. I'm happy with the outcome.
Which motor did you eventually use?
It's a pretty neat looking heater! Glad to hear you got it going.
