Replacing the Oven Bulb
douglas71
Wichita, KS
I realize the microwave is a DINOSAUR but I'm wondering if anyone might be able to tell me how to replace the oven bulb in a Litton-Aire Generation II microwave, model 8074.004. I know it sounds impossible...but other than the oven light having just burned out, the stupid thing works perfectly. The lightbulb is behind the side wall and there doesn't seem to be any way in there through the oven or the side control panel. It is an over-the-range model, any direction would be helpful!
Susan
Sorry to say that I have not changed one on this style before but from the parts breakdown there appears to be a slide cover to remove to access the bulb....kinda -looks like- it may be attached to the bottom, #49, 50 and 51.
Lamp bulb
