RF260BEAEBC/AA Two Issues - ice under lower freezer drawer and vacuum sealed freezer door
JoeG
United States
RF260BEAEBC
Samsung
We are having ice build-up under the lower freezer drawer such that eventually the door won't close. Saw in another thread that most likely the problem is drain hidden behind the panel at the back of the freezer? Clear with hot water was the suggested fix. Sound about right?
Second issue is we get a vacuum seal on the freezer door that only relaxes after about 10 minutes of being closed. When we lift up the freezer handle, only one of the little tabs comes out to break the seal (I guess the other one broke off). How difficult is it to fix.
Joe
JoeG
United States
Here's the tab that is working. When you lift the freezer door handle this is pushed into the seal.
On the other end of the door, the tab no longer comes out of the hole.
JoeG
United States
And here's where I am stuck. The panel on top of the door to access the springs is all one piece. How do I remove it without breaking it? Thanks.
The only one I've seen had a cap door above each slider. Can't you access it from the front?
JoeG
United States
Doesn't look like it. If I lift where the handle attaches, I can see the spring, I can touch it with a long screwdriver (it is out of position or broken) but there is no way to replace it. Looking around the web, it looks like a replacement part isn't made for the cap piece.
Can you take a few pics of the front of the door at the handle studs and post them here?
Never mind. Your yellow lines blocked the picture. The top of the door pops off
JoeG
United States
I just don't see how to do it without it breaking. Any pro tips on trying to remove it?
Do you think there are any clips/tabs holding it in place?
thanks
This is the parts diagram for RF260BEAEBC/AA-02:
This is the parts diagram for RF260BEAEBC/AA-01:
JoeG
United States
after much effort, I got the panel (partially) removed and could see the problem. It looks like a replacement part isn't available :(
JB weld will work and so will a good super glue. The secret is give it time to cure before using it.
