CorriGa
- RF28HMEDBSRAA
- Samsung
- 1-5 years
Hello,
I recently changed the filter on our Samsung RF28HMEDBSR refrigerator because the red light was on and we were having some ice issues with the ice maker and a generally low pressure flow from the dispenser. I assumed the low flow was caused by an old filter so I ordered a couple of non-Samsung filters on Amazon. After replacing the filter, the problem was not fixed and actually significantly worse. I then ordered a Samsung filter but nothing has changed. Our water dispenser is barely at a trickle and sometimes just drips out. The ice maker is functioning but our ice cubes are the size of uncooked shell pasta.
When I remove the filter the water supply pressure is excellent and it fills a pint glass in five or six seconds, but there's subsequently a noticeable drip drip drip from the filter housing. If I could just go without the filter I would but this leaking water ends up on the kitchen floor.
I'm not exactly certain what happened after changing that filter, but I realized that I made two mistakes that may have contributed to the problem--using a non-OEM filter and not shutting off the water supply when I swapped them out.
I'm assuming the problem is in the filter housing, but my question is how to fix it. Do I have to replace the entire water filter housing unit ($165) or can I replace the piece with the plastic star-shaped valve things?
click.linksynergy.com
Alternatively, is there a way to easily bypass that with an external inline filter and if so, how do you bypass the filter assembly itself so the dispenser and ice maker function normally?
Any tips or advice is greatly appreciated.
Samsung DA97-08006D Assy Case-FILTER;AW3,WHI - AppliancePartsPros.com
ASSY CASE-FILTER;AW3,WHI DA97-08006D / AP5584601 made by Samsung
