- RF28R7201SR
- Samsung
- 1-5 years
Hi, New here so I hope someone can point me in the correct direction. So my Samsung fridge is a little less than 2 years old (model RF28R7201SR), my concern is with the ice maker. The first issue I encountered is that it seems like when set to dispense just cubes, It now also tries to grind some of it also. Now more recently, I've noticed the ice in the maker isn't getting as cold? Meaning the ice seems slightly wet where as when the unit was new the ice was very cold to the point where it was completely solid and dry. That and when I open the door which houses the ice maker it will drip a little water trail. Also something it never did when it was new.
The temperatures have always been set the same since I got this fridge. 34F in upper fridge, 30F in middle drawer, and -2 in bottom freezer. It has no problem maintaining these temps. I'm a career auto mechanic so with translating that to my limited appliance exp, today I pulled the fridge out figuring all that would have changed is components getting dirty and so less efficient. The pics I attached are before, but I gently cleaned the cover which was awfully dust matted, pulled that cover off and the evaporator was also quite dust contaminated through the fins etc. I carefully cleaned and de-greased the evaporator, cleaned the fan blades etc. So hopefully that helps the situation?
Only reason I have doubts that it would is because although it will help efficiency, the fridge never has problems maintaining the set temperatures. So perhaps something that controls the flow of cold air to that freezer box? Last note, before the pic of the freezer i attached, I had taken the ice box out a week ago and used a hairdryer to remove all that ice buildup hanging and all other ice in the box. Sorry for this long post and thanks to anyone with good knowledge that can help.
Corrected model number
