RF4287HARS/XAA Samsung Refrigerator Ice Maker no longer is making ice
bbcewalters
Flowery Branch
RF4287HARS
Samsung
It seems I may finally be victim to the Samsung curse. I have had my French door Samsung since 2013-14 with zero issues. Today it no longer is making ice. It is not frozen over, never has done this. I can hear the motor but no ice??? Is it possible that the water line is suddenly not working or clogged? Please let me know what I can check before I call a repair person. Thanks
Does the water to your water dispenser work fine?
Another member had this same problem and has this same Samsung model number and the new ice maker I suggested fixed his: FIXED No water to icemaker after 4 years of use; water to dispenser is fine
Here's the ice maker for your model you can order:
DA97-07365G Assy Ice MAKER
There is a ice maker troubleshooting flowchart on Page 83 here: https://drive.google.com/open?id=1U5dJv34LbhJc5cjZRQCHRsseIwmSEj0w
Does Ice Maker rotate when pressing the Ice Maker testing switch(over 1.5 sec)?
IF NO:
1) Replace the Ice Maker Kit
2) Check/Replace the Main PCB input signal
(Micom IC01 Pin #37 - “0V”)
bbcewalters
Flowery Branch
I did use the test switch and heard the "chime" but not anything else.... but It did chime..... what does that mean?
Thanks for your response.
IF NO:
So if you heard the chime and the ice maker did not rotate, that means the ice maker is bad--->Order and replace the ice maker. I posted the link to the ice maker in post #2.:)
