FIXED RFG297HDRS continuously dispensing ice
Drewski99
Milwaukee
RFG297HDRS
Samsung
Today I when went to get ice from the automatic ice maker the door for the ice maker opened, auger turned on to dispense the ice, but wouldn’t turn off. I opened the door to the fridge to stop the augur. The ice dispensing door stayed in the open position and would not close. Here is what I have done so far:
1. Unplugged the refrigerator for 20 minutes to see if it would reset. When I plugged it back in the ice dispensing door remained open and when I depressed the dispensing lever the augur started and would not turn off.
2. I removed the entire dispensing unit. I unplugged the control board and the dispensing unit from the refrigerator and closed dispensing door by physically turning what I believe is actuator. I plugged everything back in but did not reassemble. Once I plugged the power back in the dispensing door opened and augur began turning and would not shut off.
Any suggestions?
Thank you in advance
Drew
Drewski99
Milwaukee
Thank you Jake. You were correct. I ordered the part, installed it today and everything is working again.
Drew
Excellent Drew, glad to hear the new dispenser module fixed it. (y)
