RGB530DEP2WW Oven randomly turns itself on and off. Knob sometimes makes faint buzzing sound.
jayman210
Texas
RGB530DEP2WW
Hotpoint
So our oven turns itself on for about 20 seconds then shuts off. This happens at random times throughout the day and night. Another issue when everything is supposed to be off you can hear a very faint buzz sound behind the temperature control knob. You have to lightly touch the knob to make it stop.
Things I noticed after a basic visual inspection:
The blue tags were burned/melted on the ignitor wiring. They easily peeled off but the wiring itself looks untouched.
The right clip that holds the thermostat inside the oven is missing causing the right side to touch the back wall. I bent it a bit to prevent this.
Any advice /info is appreciated!
The problem is the clock, which controls the oven.
Here's the clock oven control board for your model you can order:
WB27T10469 Clock
jayman210
Texas
Wow the clock, I would have never guessed. I thought it functioned as it's own separate clock timer.
Nope, it controls your oven too.:)
