Rheem 80 Gallon Water Heater
slackkeymike
Huntsville, Alabama
Model 81V80D
You can’t buy these anymore (thanks to some obscure language in the Affordable Care Act, If i recall). Anyways. This one in our house never saw heavy use. The other one did and it failed recently. I want to try and extend its life by once again replacing the heating elements and most importantly the sacrificial anode. First, can I do this? Second, does anybody know it’s location? There are several plastic plugs on top. I’d really like to do this. Help appreciated.
Yes Mike, you can do that.
This video shows you how:
[video=youtube_share;wzecqGyCllU]https://youtu.be/wzecqGyCllU[/video]
slackkeymike
Huntsville, Alabama
Jake, thanks. Since it is working fine, seems a good way to possible extend its life. I wish I had known about this before. I have limited clearance, so I will have to cut it as it comes out. Carbide blade and die grinder should do it. and, I am buying one of those segmented anodes.
Sounds good Mike, let us know how it goes when you get to it.
