Rinse, Drying, End lights flashing on Miele G2140
Rosco
Toronto
Miele G2140
Miele G2140
This problem started a couple of weeks ago on my 11 year old Miele (Inspira G2140) dishwasher. I put in the dishes in and loaded the powder detergent, and (as always) ran the Normal Cycle, and went to bed. Upon rising the dishes were wet, there was no water in the unit other than the small amount that is left by the drainage pump. And all 3 lights - rinse, drying and end - were flashing together. I went on line and read a posting on your site that sounded familiar. With the information I read on-line, performed the following checks:
1) I reset the unit and ran the normal cycle again. In this case no water entered the Unit, so I checked the line in (no buildup that would cause a blockage).
2) Took out the filter basket on the bottom of the unit and as best I could used my "two pronged fork" to see if the circulation pump impeller was stuck. On this model it's hard to tell if it was, but I wiggled it around. Again, when I ran it, no water came in. I ran a few more resets and memory clears, but with no luck.
3) Called Miele's help number and talked to a service person who said it was the electronic heater element switch... Hummm...that didn't sound right, but maybe they're right.
4) At this point I about to call a Miele repair guy who will probably tell me I need a new circulation pump to the tune of 750+ bucks.
5) BUT then, a miracle happens a few days later, it just starts working. Perfectly. Like there was never anything wrong with it.
6)Until, today, a week later the same problem starts again. Only, this time I'm a little more educated about it, so having discovered the dishes inside the machine had gone through the rinse cycle, (they were still a bit wet) but not the wash cycle and see that the rinse water had been been removed by the drainage pump, I tried a little test.
7) After doing a number of 'resets' I ran the 'rinse and hold' cycle and lo and behold the water entered the machine, and it went through a complete rinse cycle, including draining the water from the machine. (So the circulation - and drainage - pumps seem to work...)
8) But when I then tried the Normal cycle it went back to not letting ANY water into the machine.
9) And when I tried, again as a test, to run just the 'rinse and hold' cycle, this time no water entered.
10) So the problem is intermittent - which suggests some kind of electrical issue - but of course I'm only guessing.
Can anyone help me here? It's infuriating to think that a repair person will show up and give me a new pump when this one seems to be capable of working - albeit intermittently. Any thoughts?
John Stone
Chicago, Il
I know this thread is old but maybe this will help. There should be a way for you to retrieve the fault code for your machine. I called up Miele, and they explained to me how to do it. Some machines will do so automatically on the display, where others show the flashing lights, indicating that a code has been registered. You can then get an idea where the fault is occurring. If you come up with an F14 code, there is the strong possibility that the pump or the pressure switch associated with it is bad. Given that a basic Miele can now be purchased for about $800 (and it works great...I just bought one) it doesn't make much sense putting a lot of money into a 10 yr old machine.
